주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Wi-Fi가 탑재된 3세대 Apple iPad의 수리 안내서, 분해 정보, 문제해결 정보를 제공합니다. 16, 32, 64 GB 저장 용량으로 제공됩니다. 2012년 3월에 출시되었습니다. 모델 번호 A1426으로 식별됩니다. 수리 시 열을 가하고 조심스럽게 들어내는 작업이 필요합니다.
Punctured battery while replacing, help
As I was replacing the battery on my iPad 3 I accidentally punctured the battery and I have now (as of the time I am posting this) gone two days ago without touching the battery and leaving it in a place where it won’t catch fire. Is there anything I can do to take out the battery safely? It is also important to not that I took out the logic board and I was planning on replacing the battery anyways. The battery did also smoke up the first time and when I tried removing it more it caught fire. If I go back will it explode or am I safe?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
Phone local fire department for advice?
의
댓글 달기
답변 3개
Found another user who had the same problem: maybe try, with your phone ready to call 911 at any moment?
Battery punctured while removing (small flames) Still need to remove
이 답변이 도움이 되었나요?
점수 0
댓글 달기
These batteries tend to flame and smoke when the plates touch. I have never heard of one exploding yet.
Always keep yourself safe with Li-Ion batteries. They are evil.
I doubt a repair shop will touch it.
I would go outside and do it.
Disconnect the battery making sure it is not glued to the shell and launch it.
If it flames out, no biggy. Now connect your new one.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
My power bank is not working
Update (11/07/24)
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
johndiaz693 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 5
지난 30일: 24
전체 시간: 553
