주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lenovo Yoga 라인업의 변신 가능한 "랩렛(laplet)".
Some keyboard keys don't work
Situation: Liquid was spilled on lenovo yoga 710-14 ikb laptop. After drying and cleaning, it appeared some of the keys were not working. So I ordered a replacement keyboard, but some keys still didn’t work ( qweruiop). I assumed the new keyboard was faulty, so requested a new one. On the next one, again the same keys don’t work. Can it be boards fault? Or is there a chance both new keyboards are the same faulty?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
Hi,
It would be highly unusual that 3 keyboards (original plus two replacements if this is what you mean) exhibit the same fault characteristics.
The common factor is the motherboard or the keyboard ribbon cable if you re-used the same one.
Try connecting and using a USB keyboard just to eliminate the remote possibility that it is a software problem.
Did you also clean the connector socket, where the keyboard ribbon connects into the motherboard, with Isopropyl Alcohol ?
Don’t know your laptop but if you re-used the original keyboard ribbon cable on the replacement keyboards, did you clean the ends of the cable that plug into the motherboard and the keyboard with IPA as well? Try not to grab the ends of the ribbon cable with your fingers after you have cleaned them as this can make for a bad electrical connection
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Thank you very much for the answer. The ribbon is new with every keyboard. So this shouldn’t be the issue.
I connected a Bluetooth keyboard and it works fine, so its not software problem as well.
I’ll try cleaning the board more, hope it helps.
의
댓글 달기
답변을 추가하세요
Erika Gurcan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 20
전체 시간: 1,719
