주요 콘텐츠로 건너뛰기
{A1706 / EMC 3071}—2017년 6월 출시, 이 MacBook Pro 13”는 Kaby Lake 프로세서 최대 3.5 GHz Core i7 및 Turbo Boost 최대 4.0 GHz 포함.
276 질문 전체 보기
820-00239 logic board - temp sensor orientation.
Would someone be able to tell me the orientation position of U5860 on the 820-00239 logic board.
I can only make out a couple of numbers but not the dot so I will have to go with which way the numbers face.
Thanks.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
@imicrosoldering U5860 is a TI TMP461 sensor. Here is the datasheet for it. With the writing on the sensor up Pin 1 is to the top left. On your board pin 1 is the bottom left pin so the writing would face to the outside (left hand side).
Due to the size of the sensor,the direction of the sensor is not visible on the teardown .
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thanks for that. The Mac arrived with paperwork saying “Chip got knocked off” along with the sensor taped to it. It didn’t say all the pads were also missing so I will have to turtle it. I can usually determine which is pad one on the chip if it has two grounds which it has but they must be separate or the chip is faulty. Thanks again Oldturkey.
댓글 달기
@imicrosoldering - Did you look at the iFixit teardown to see what it shows?
MacBook Pro 13" Touch Bar 2017 분해도 jump down to Steps 3 & 4
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Chris Stables 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 5
7일 전: 7
30일 전: 7
전체 시간: 363
