주요 콘텐츠로 건너뛰기
재봉틀 수리 및 분해에 대한 정보는 다음 안내서를 참조하십시오.
20 질문 전체 보기
Imperial 520 Sewing Machine Repair
I have a vintage Imperial 520 Sewing Machine whose mechanism is stiff, and wont run freely, to the point where only cranking by hand works - too much for the motor.
I have narrowed down the problem to the drive shaft that spins the bobbin holder 180 degrees - it’s quite stiff. I tried 3in1 motor machine oil, but that made it worse.
I’d like to take it apart and give it a good cleaning, but there is a cam attached to the shaft by some kind of pin (see image, center, a little out of focus)
So, my question is how do I get that pin out (or otherwise remove the shaft, and then how do I clean and properly lubricate that shaft?
Thank you.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
@jonathonmckay you need a drive pin punch for that. Something like this you get them relatively cheap at home depot etc. After that check your shafts for any sign of having been rubbing against a worn bushing etc. Use some grease to lubricate since oil will most likely sling off when you use the sewing machine.
이 답변이 도움이 되었나요?
점수 3
댓글 7개:
Had a look at the link you provided. I'm guessing I use those to basically bash ... uh, tap the pin out with a hammer. Thanks, I'll give it a shot.
Yep, give it a try and happy bashing. Some of those are tight....
Totally worked!
Actually, I used a nail set. A couple taps with a light hammer, and the pin popped out far enough I could remove it by hand. Cam needed some convincing to come off, but used the same tools and I'm set!
Thank you!
@jonathonmckay that is great. Thank you for accepting my answer. Now the fun part. As you continue to work on your sewing machine, make a guide for it. https://www.ifixit.com/Guide/new that way others can maybe fix their machine as well. Those are speciality guides that will be really useful.
Is there anyone who has a users manual or service manual for the Imperial 520 sewing machine? Thanks
댓글 2개 더보기
댓글 달기
답변을 추가하세요
Jonathon McKay 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 293
