주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
Water damaged iPhone 5 suddenly turns on again
So almost one year ago, I dropped my iPhone 5 in water I tried the rice trick and it didn’t work. My iPhone 5 have been sitting in the cabinet for almost one year I tried to power it on a couple of times but yesterday I charged my iPhone for no reason and it power on. I let it charge overnight. I updated it to IOS 10.3.4 and restore it (I forgot the passcode on my iPhone 5). I tested some apps to see it working but the when I use the camera with flash the iPhone restart itself But when I tried the camera with flash while charging it didn’t restart. So how does this happened?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
@adiplayz corrosion from the previous water damage is the likely culprit. you can of course still clean it but ultimately you know you will have to replace the camera etc.
Here is my answer to a similar question. "Rice does not work. It will not prevent corrosion! The very first thing you want to do is to stop using your phone. Stop right now and do not continue to charge or sync it. The very next step I would do is to disassemble it by following this guide. Take a careful and close look at all components and connectors. Truly assess the damage. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. After that I would suggest that you clean it a couple of times in sterile water, not drinking water. Use a soft brush and clean it very, very thoroughly with the sterile water. Depending on the amount of corrosion, you may have to remove all the EMI shields. Once you got the gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for a 3G but it is still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning. Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later on. Do not use drinking water, if you need to use water, use sterile water. Also, you do not need to leave it to dry for a day. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate the water. The importance here is the cleaning. Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now. Keep in mind that water damage is the hardest to troubleshoot and to repair.Hope this helps, good luck.
iPhone 이미지
안내서
Repairing iPhone Liquid Damage
난이도:
어려움
1 - 2 hours
iPhone 5 Logic Board 이미지
안내서
iPhone 5 Logic Board Replacement
난이도:
조정
1 - 2 hours
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Adi Malikul 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 63
