주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony α6500은 모델명 ILCE-6500으로 식별할 수 있습니다. APS-C 센서가 탑재된 미러리스 디지털 E-마운트 카메라입니다. Sony α6500은 2016년 11월에 출시되었습니다.
Sony 6500 Base Damaged
The Base of my Sony 6500 was damaged in that a tripod screw broke inside the camera body and now the camera cannot be used on a tripod as the screw cannot be removed. Is it possible to have that bottom OR the complete outer camera replaced
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
I'm not sure how different the models are but here is a disassembly video of the A6000. Hope it helps!
https://www.youtube.com/watch?v=y3CCJtD0...
의
댓글 달기
답변 1개
가장 유용한 답변
Hey Douglas,
I had a similar thing happen with my a6000 a while ago. You could opt to replace the outer housing, but depending on how well the tripod screw is lodged, it could be removable with no disassembly. I covered the bottom with painting tape and made a hole in the tape where the screw is is. I then used a small bolt about the size of the hole, put a small dab of glue on it, and let it set. Once it set for a long time and hardened, I simply twisted it out.
Hope that works for you, best of luck!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Douglas Quick 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 29
전체 시간: 639
