주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
a7R II(모델 번호 ILCE‑7RM2)는 Sony의 2015년형 풀프레임 미러리스 렌즈 교환식 카메라입니다.
Menu scrolling through itself like crazy
My Sony A7S Mark 2 is moving the menu by it self please how do I fix this?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 5개
hi, i have the same problem with my Sony A7ii. Menus switching on its own and sometimes goes back to normal then switching and scrolls again.
Did you already FIX yours??
Thank you :)
의
Same problem. Any help?
의
Me too. Anyone sort it?
의
Very late reply. Got mine fixed at the nearest camera repair shop for USD65.
They say this is a common problem with Sony A7II after sometime...
의
Hi. Did they say what the problem was that fixed the camera? 65$ is pretty affordable. Thanks
의
댓글 달기
답변 2개
가장 유용한 답변
Hey, Shakily_17
The issue could be that you need to replace the buttons, but it's likely that a ribbon cable isn't fully connected or it is damaged. This issue can be found in other devices such as the Sony Dualshock 3 and the Asus Zenbook.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Sounds like a "Stuck Button" Problem. Common with most devices that you use the buttons, when they aren't cleaned they can stick. Even if the "External Buttons", or the button layovers, are cleaned, the internal buttons may be dirty. Try cleaning the buttons with Isopropyl Alcohol, and a soft electronics towel. If that doesn't work, check the cables and clean the internal buttons and cables if necessary.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
shaikly_17 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 50
전체 시간: 1,737
