주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple Magic Mouse는 Apple Inc.에서 제조 및 판매한 멀티-터치 마우스입니다. 2009년 10월 20일에 처음 발표 및 판매되었습니다.
Can I replace the laser bulb?
Everything is working on my Magic Mouse but the laser sensor, itself. I can gesture, scroll, right click, double-click to select a word. BUT the laser no longer comes on, so I can't move the pointer. Can I replace the laser?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 8
댓글 1개
can you explain me in detail that how you fixed it kaath9?
의
댓글 달기
답변 2개
선택된 해법
I've never seen this part fail. I would suspect a failed solder joint. Of course if it is less than a year old, get a warranty replacement from Apple. If not, I'd tear it down and see if I could spot the problem. Here's the teardown: Magic Mouse 분해도
이 답변이 도움이 되었나요?
점수 4
댓글 5개:
You're right mayer, mine wasn't working well, only clicks and movements but no cursor moving. Once opened, I've heater the laser pinouts with a soldering iron and it's working well now. The problem now is to fix the batteries plugs. In order to disassemble properly, we need to cut 2 plastic pieces who maintain the metallic rounded batteries plugs on the frame
의
Can I solder without removing the capacitive sensor ribbon nor the battery case? @kospeia Did you achieve to do it?
의
What Part of the mouse do you solder once you open it up?
의
Asher Solder the place where you no longer have continuity.
의
Thanks Mayer
의
댓글 달기
I had the same problem! After several attempts, I tried to push the lens with a pencil eraser, now it works fine
이 답변이 도움이 되었나요?
점수 0
댓글 3개:
It makes me laugh, this is ifixit.
의
Hello fabrizio,
Did you just press it up, without opening the mouse?
Thanks in advance!
의
Hello Antonio, yes, you can do it without opening..... but ... the operation did not last much for me :-(
I think at this point that you have to open it and solder contacts with a soldering iron!
의
댓글 달기
답변을 추가하세요
kaath9 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 12
지난 30일: 33
전체 시간: 17,586
