주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
이 Apple Cinema Display는 M8149 모델 번호로 구별되며 2000년 7월에 처음 출시되었습니다.
Erase mark on screen?
A Sharpie permanent marker touched the screen of one of my Apple Cinema Displays, leaving a mark about an inch long. Does anyone know the best way (any way) to remove such a mark with no (or the least possible) damage to the screen?
Maybe a chemical that will react with (remove) the black mark while not harming the display (or not too much), applied with Q-Tip or something? Magic Eraser? Any ideas?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Use a LCD friendly spray to do it. Alcohol works too. For Sharpie, I'd use alcohol first since it usually works. Rubbing the screen would work too, but be careful what you use to do this. Some things damage or scratch the panel.
If this doesn't work, then leave it. You'll do more harm then good.
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
+ for the editing..try for the fourth, it's subtle..
의 공유
Anodex is a product that seems to be highly recommended. Anyone have any experience with it?
의 공유
댓글 달기
답변을 추가하세요
John Brandt 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 20
전체 시간: 1,210
