주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Mazda Millenia는 일본 자동차 제조사인 Mazda가 1993년부터 2002년까지 생산한 고급 승용차입니다.
How to change ignition
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 4개:
James Clark ignition what? You need to tell us what the issues are and what you are trying to accomplish. Try to use more than 4 words ....;->
의 공유
@James Clark Do you want to change the ignition switch assembly, if yes, do you also have a security system (anti-theft)? Typically you will need a hammer and very sharp chisel as part of the process but lets see exactly what it is that you need to do first please.
의 공유
Ignition switch?
With lock cylinder, or without?
or,
Ignition module?
Ignition lockout/immobilizer?
Ignition relay?
More information required.
What are the symptoms, or how was the ignition diagnosed as the issue?
Help ‘us’ help you!
의 공유
My bad, just saw someone covered those details, thank Turkey and Duane, they're right on point.
Regards.
의 공유
댓글 달기
답변 1개
Here are the instructions for replacing the switch:
Disconnect negative battery cable. Remove steering column upper and lower covers. Remove screw(s) retaining ignition switch to steering column. Disconnect ignition switch harness connector. Remove ignition switch. To install, reverse removal procedure.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
hope this helps
의 공유
댓글 달기
답변을 추가하세요
James Clark 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 17
전체 시간: 1,149
