주요 콘텐츠로 건너뛰기
This computer was released by Asus in 2014.
EeeBook wont boot, not even to BIOS
My EeBook turns on (the screen backlight is visible) but everything else remains black. There is no bootscreen and no BIOS. Multiple attempts at restarting or holding the power button down for longer periods of time give no reliable results.
Trying to enter BIOS with F2 (and many other buttons includings Esc, F8, F10, F11, F12) all yield no results.
Sporadically after many attempts the Laptop does sometimes turn on.
Even though this problem occurs both when plugged in and out, my theory is that this is related to a dying battery.
Any solutions or similar experiences?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
@lufthomas start off with a new battery. Use this guide to replace it
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Firstly try to disconnect all peripheral devices and remove all USB devices and SD media cards.
Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds to drain all residual power and restore default startup settings.
Reconnect the AC power adapter (but do not insert the battery), press the Power button, look for glowing lights near the caps lock and num lock keys, and listen for sounds of a fan or other moving parts turning.
If the computer starts normally after performing a hard reset, you are done troubleshooting.
You can also make a Windows boot media, boot off that, delete all partitions off your drive, start the setup.
Otherwise reading Fix Laptop/Computer Won’t Turn On.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Thanks for the quick reply! I was hoping to avoid the hard reset option since the battery is non-removable on this laptop. Also the computer sporadically does end up starting (although this takes a long time and many attempts). I guess I'll have to do a hard reset then.
Thanks for the help. I'll post an update if the hard reset works.
@lufthomas OK, thank you, please feel free to ask if there's any other question.
댓글 달기
답변을 추가하세요
Thomas 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 18
전체 시간: 1,711
