주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
9월 20일 출시된 Apple의 2019년형 메인스트림 iPhone으로, 6.1인치 LCD 터치 스크린, 듀얼 카메라를 탑재했으며 6가지 색상으로 출시되었습니다. iPhone XR의 후속 모델입니다.
Screen replacement compatible with XR?
My iPhone 11 screen has cracked and I cant find an 11 lcd screen replacement to buy anywhere online to repair myself. After some looking for picture of both the XR and the 11 under the display and the screens itself they look very very similar. Could I possibly buy an XR display and use it on the 11 with it fitting properly?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 1개
XR is not Compatible with 11
의 공유
댓글 달기
답변 3개
선택된 해법
The display modules look the same, but you can’t install the screen from iPhone XR to iPhone 11 because they have technical incompatibilities.
이 답변이 도움이 되었나요?
점수 5
댓글 달기
No. They may look the same but they both have something that prevents you from using a xr screen on a 11
이 답변이 도움이 되었나요?
점수 1
댓글 9개:
https://youtu.be/AIgTrL9xbV0
you cannot interchange 11 & XR or vice versa! See video.
connectors are different.
=== Update (01/02/2023) ===
After reaserching and actually trying a swap from 11 to XR I found they do not work. So no compatability.
의 공유
I connected an XR screen to an iphone 11 and the display works but touch does not.
의 공유
I have also plugged an iPhone XR screen onto an 11 only to find out that the touch did not work as someone else said. You can trim the excess width from the display plug and then plug in vice versa from the way the XR screen is suppose to plug in and then you realize the connectors are the same but again, as someone else here answered, technically they are different somehow bc you end up with no touch. I’ve never had any issues switching btwn series 7/7plus and 8/8plus screens tho.
의 공유
I posted this long ago and recently I have found that they are different FPC connectors on the flex and and the boards, ie sizes do not match. Thanks for your reply. I do know about the 7/7+ and the 8/8+ screens and did you know the batteries also are compatible ie 6s/6s+ with 7/7+, and the 8/8+ I think the X can work for testing purposes as well, not sure cuase I have not tested that yet.
의 공유
If you flip the connection around they will plug in but touch won't work. I did this about 2 weeks ago.
의 공유
댓글 4개 더보기
댓글 달기
So, the XR screen will power on on an 11. But touch may not always be consistent and could have problems. And 11 screen on an XR may power on at best, but no touch. An 11 screen may not even power on at all on an XR. So you might be able to use an iPhone XR screen on an 11, but just prepare for inconsistent touch and potential touch issues, as well as losing True Tone and Face ID.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Splityou4 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 7
지난 7일: 58
지난 30일: 201
전체 시간: 38,939
