2001 Ford transmission problem
2001 Ford Explorer with 4.0 overdrive light was flashing did not want to downshift now does not pull at all what could possibly be the problem
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
Flashing light tells you that you have a code in the computer, will need to get that information to get more help. Will it drive if you manually shift it into 1 then 2? Check fluid level according to the owners manual.
의
댓글 달기
