이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 1개:
Hi,
Maybe a faulty 3.5mm stereo socket or socket connection in the amp. Assuming that you are connecting via a stereo audio cable with 3.5mm stereo plug at one or both ends.
Have you tried a different cable to connect from the devices to the amp, to prove the problem is in the amp, you didn't say?
What is the make and model number of the amplifier?
Hi,
jayeff 의
