The LCD readout symbols are fading. Is there an easy fix.
I have several TI-30X iis calculators I use in my classroom and the LCD readouts are fading. Is there an easy fix or are they shot?
좋은 질문 입니까?
좋은 질문 입니까?
Your calculators might be having a similar issue to the TI-84 Plus calculators where the ribbon cable is degrading. If you have soldering experience, then you might want to take a look at this guide here: Texas Instruments TI-30X IIS Battery Replacement for instructions on how to take apart the calculator. Refer to this topic on Cemetech for instructions on how to fix a ribbon cable: https://www.cemetech.net/forum/viewtopic...
해당 답변은 도움이 되었습니까?
sounds like a lot of work for a non -techy
If you don't want to try fixing the ribbon cable, then you can try Duane's suggestion of replacing the battery and adjusting the contrast. Although I find it unlikely that's the issue, hopefully it is something as simple as that. Otherwise you'll have to find a friend or student that's willing to take on such a project, buy a whole new calculator, or just deal with a partially broken screen.
Sounds like the Contrast setting is lowering, how are the batteries also?
해당 답변은 도움이 되었습니까?
Poor description on my part. You can see some numbers or parts of numbers.
I stick with my suggestion of adjusting contrast, otherwise, time to replace the unit.
24 시간 전: 1
7일 전: 16
30일 전: 45
전체 시간: 1,551
