주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2017년 3월 출시, 모델 번호 SM-J727로 식별 가능
J7 Crown Black Screen
I have a J7 Crown S767VL that has no screen display it stays black phone is still powered on and when I try to hard reset it doesn't fix the issue I have tried to power off by holding power + volume down button for 20+ seconds and after about 15 seconds of holding buttons it vibrates every 1-1.5 seconds and does not power off. I have been attempting to factory reset with black screen with no luck and have exhausted my options available online. Please give me suggestion(s) on what I can do it is a straight talk phone.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 달기
답변 1개
It sounds like an LCD fault. Has the phone been dropped in water or dropped on a hard surface?
이 답변이 도움이 되었나요?
점수 0
댓글 12개:
I do not believe it has gotten wet or dropped, it is in pretty pristine condition as far as I can tell I was thinking it was a corrupted firmware issue
의
You will need a new LCD if you haven taken phones apart then you can replace the screen yourself or take it to a repair shop. It will be a whole lot cheaper replacing it yourself if you do that go here https://www.amazon.com/Replacement-Digit...
의
Is there a way to try to perform a factory reset without the ability to boot in recovery mode and being unable to do it through settings?
의
Hope this helps
의
Yes if you have a computer
의
댓글 7개 더보기
댓글 달기
답변을 추가하세요
Corbin Dallas 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 20
전체 시간: 1,942
