주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lexus RX300 1세대 럭셔리 세단 SUV 크로스오버.
Engine Misfire after heating up
Hi, I have RX300 99’model. the engine misfire when its heating up and the heat indicator show just a little over half. Already checking coils, already changing plugs. and i even changed the distributor. yet the problem still persists . it is not like misfiring all the time but when i try to over take or climb up, i cannot raise above 50 at all. i had to ease on the accelerator little bit and press it again then ease again then press it again. Can anybody help me with that please?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
If you accellerate slowly going down the highway can you slowly gain speed up to 70MPH? Misfire while trying to accellerate quickly is usually a problem with the MAF or MASS or MAP sensors. If you cannot go up to a higher speed under heavy or normal accelleration, you also can have a fuel delivery problem, low fuel pressure, weak fuel pump, clogged fuel filter, problem with clogged intectors, etc. The best thing to do is have the computer scanned for the data and watch live to see what is happening under heavy accelleration even if you are in the parking lot.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
fa sao 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 15
전체 시간: 912
