주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
낮은 오디오 주파수를 귀로 전달하는 범용 오디오 장치입니다.
Only 1 amp working!
I have 2 amps set up everything is wired up good I checked all my volts with a multimeter ,and everything checks out . But it seems that I can only have 1 amp wired to get any power . I wired each of my amps to 1 power source and each amp started up so is there a reason I can’t set up my highs amp and my bass amp ?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
@jaimeibarra what make and model are your amps. How did you wire them up? Schematic or picture?
의 공유
댓글 달기
답변 1개
가장 유용한 답변
There might be an issue with the remote turn-on lead. Some radios don’t provide enough current out of the remote lead to turn on multiple amps. Try running 12V from the battery to both of the amps remote turn-on leads and see if they both turn on. If that works, then you can use a relay connected to the radio’s remote turn-on lead and switched 12V power to switch your amps on. Also check to see if you get a voltage drop when both amps turn on at once. It’s possible that one of the amps is going into protection mode due to under-voltage. There could be a wiring, car battery, or alternator problem that isn’t supplying enough current for all your car’s electronics.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Jaime Ibarra 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 23
전체 시간: 450
