주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Cruzer Blade는 SanDisk에서 출시한 USB 2.0 플래시 드라이브입니다.
Write protected pendrive issue
my pen drive has been write protected, format related issue.
I did everything like in registry edit, cmd command, used tools, but the problem remains same
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 24
댓글 2개
Have you attempted to use any kind of write protection removal or partitioning tools?
의 공유
usb write protected problem
의 공유
댓글 달기
답변 5개
가장 유용한 답변
First I maked the bootable USB of Ubuntu then I installed Ubuntu in dual boot successfully, but now I am formatting my SanDisk USB then it is showing me error of " write protected". I tryed most of the ways from Google but that is not working, my USB is also showing in disk manager but, I am not able to format or delete the partition, can you help me please 😢🙏
이 답변이 도움이 되었나요?
점수 4
댓글 달기
Download Ease partition primary
And click own write protection clean
It will scan usb and clean its write protection problem
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
Is This One Really Working?
의 공유
댓글 달기
Sadly there just isn’t any way to salvage your USB drive.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Possible causes of read-only mount:
  • Security configurations on the Operating System; Too many to list, but they are altered using Windows Registry; Google around;
  • Corrupt Filesystem / Dirty Bit set; Use chkdsk;
  • Corrupt partition table; Use a drive partitioning utility; Pendrive will be erased but will be usable later;
  • Pen drive microcontroller reporting faults; It means it’s time to buy a new drive. I’m still looking into possible temporary fixes to make the drive last a few more days, but it looks bad.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
의 공유
댓글 달기
Its seems that Cruzer Blade usb disk is awful. I have the same problem “write protected” and I have found many other posts in internet with the same problematic usb disk.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Rohit Dharan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 12
지난 30일: 59
전체 시간: 6,414
