주요 콘텐츠로 건너뛰기
6s와 유사한 하드웨어 사양의 4-inch iPhone은 2016년 3월에 출시되었습니다. 16/64GB 저장 옵션 및 은색, 스페이스 그레이, 금색 또는 로즈 골드로 제공됩니다. 모델 A1662 및 A1723.
1049 질문 전체 보기
iPhone SE rear camera issue.
Hei.
Having issue with a rear camera and flashlight not working aswell. The front camera works nicely. The phone has a water damage history. Firstly the pp1v2_camera was missing so made a little jumper from PP1v2 line. PP1v8 line is present, also the i2c lines have 1,79 volts.
Only power what i am missing are the PP2v5 and PP2v85 but these are only present when camera is opened in phone - right ? The diode values didnt showed any short circuit to ground.
Also tried a new camera also - no luck... Any ideas ?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
You need to confirm you have the PP2V rails while the camera app is open before you can trouble shoot any further. I know it is a pain trying to measure these. You might have to solder some wires to take the measurements.
댓글 달기
답변 1개
Water damage—-the problem is where the water went. The *most likely* problem here is corrosion at the connector.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Hei,
Thanks for the reply. The connector seems OK when looking with microscope.
Does someone have SE rear camera FPC diode reading ? zxw unfortunatley does not have it.
댓글 달기
귀하의 답변을 추가하세요
Kaspar 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 73
