주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
JBL에서 제조한 JBL Charge 2+는 JBL Charge 브랜드의 2세대 제품입니다.
JBL Charge 2+ battery replacement troubles
so i replaced the battery on my charge 2 plus with the one listed on ifixit websiteJBL Charge 2 Plus 배터리 교체 . when i plug it int to charge the battery it just flashes on the first battery light forever. so i reset the charge 2 by holding the phone and volume up button at the same time and now it turns on when plugged in and makes a really loud but deep beeping sound over and over even if its connect to my phone. Any help would be great.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 3개
가장 유용한 답변
Switch the polarities on the batteries (red+black wires)
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Switch red exterior wire with black exterior wire, and red interior wire with black interior wire. It worked well for me when replacing battery.
make sure wire colors match the previous battery
이 답변이 도움이 되었나요?
점수 1
댓글 달기
same thing happened to me. You can either disconnect or just snip and solder the wires as others have said. If you don't want to do that, there are actually two revisions of the Charge 2+. The first revision shares a battery with the charge2 as the ifixit part suggests (part #: GSP1029102). The 2nd version has the polarities of the battery reversed and has part number GSP1029102R (note the R at the end). Other vendors have this battery with the correct polarities for the 2nd revision charge 2+ if you aren't comfortable reversing the wires.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Rob 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 35
전체 시간: 1,457
