주요 콘텐츠로 건너뛰기
6s와 유사한 하드웨어 사양의 4-inch iPhone은 2016년 3월에 출시되었습니다. 16/64GB 저장 옵션 및 은색, 스페이스 그레이, 금색 또는 로즈 골드로 제공됩니다. 모델 A1662 및 A1723.
1049 질문 전체 보기
went through the washing machine and was water damaged
my apple I phone went through the washing machine and was water damaged iv changed the screen now as it was smashed can I still get the water damaged phone fixed
Update (11/25/2019)
can my I phone be fixed after water damaged and the screen was fixed when we found out
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
It depends on what you mean by fixed..if you have non backed up precious data you need to recover you may try getting it at a reputable repairer into microsoldering and hope for the best. If you hope to fix it yourself for normal use I would discourage you to be honest, the iPhone SE are quite bad to recover on their own even when they suffer mild liquid damage and yours has gone through a full washing cycle with a broken screen..maybe also plugged into mains to see if it still worked afterwords. Chances of selfrepair in my opinion are close to zero.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
amanda 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 3
전체 시간: 39
