주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Chrysler는 2007년 8월 16일에 2008년형 모델로 Chrysler Town & Country를 출시했습니다.
My radiator plastic cracked
Can i fix the crack in my radiator (the plastic right above the top transmission/ac coolant lines) with j.b. weld? I have tried every bars leak they make. And 1 other kind of stop leak but they jus get blown out by the pressure.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
A new radiator is the only real solution.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Plastic welding is an option. Plastic welding follows the same basic principle as metal welding. Add material, apply heat, everything fuses together. With plastic welding, there are lots of different types of plastic. However, plastic welding in the auto industry has been a thing for some time, so it’s more likely you can have success. Nylon is the plastic I read about in use in radiators.
An airless plastic welder is little more than a soldering iron, but I have found advantages to them over a soldering iron. Mostly the tip is very large so heat can be applied over a large area.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Shawn Patrick 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 15
전체 시간: 705
