주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2015년 3월에 진행된 Apple의 13" MacBook Pro Retina Display 업데이트(모델 번호 A1502)는 5세대 Intel Core i5 및 i7 프로세서를 탑재하고 포스 터치(Force Touch) 트랙 패드를 도입했습니다.
Service Battery message still given after ifixit replacement
The “Service Battery” message is still be given in the battery drop-down menu after I replaced the battery with the iFixit kit. It seems like it was a successful installation other than that.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 달기
답변 3개
RESET SMC
MacBook의 SMC 재설정 방법
이 답변이 도움이 되었나요?
점수 0
댓글 3개:
Resetting the SMC is a temporary fix if the battery is faulty but good idea to try at least.
OP check the battery health with an application called coconut battery which can be downloaded online.
After SMC you may see the service battery message dissapear but reappear again if you drain the battery and charge it again indicating the system has found something wrong with the battery.
I also replaced the battery with the iFixit kit. The SMC reset didn’t help, I still get the message: “Service Recommended”. Is it a fault with the battery delivered with the ifixit kit?
Contact the iFixit store for a replacement.
댓글 달기
This isn't a problem with the new battery, once the chip detects that the original battery has degraded past 80% (or so) or has started to rapidly degrade and inflate, the message will trigger and it's impossible to remove without paying for an official battery change from apple. This is obviously a way for apple to limit what people can fix and sell on (nobody will buy a phone with a "severely degraded battery message" even if the battery is effectively brand new and and 100%).
이 답변이 도움이 되었나요?
점수 0
댓글 5개:
That is not true! you need to reset SMC fully to clear the set value. Or the battery is defective.
So how do you do that ?
@esnew -Did you follow the steps in the guide rustedchip pointed to just above?
Im not sure where that is. Looking for rustedchip
댓글 달기
Had a similar issue recently, tried two new batteries but service recommended message still present. Coconut Battery confirmed both new batteries were healthy. SMC Reset did not help but on a whim I tried an NVRAM Reset and bingo, message went away!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Gregory Brunkalla 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 22
전체 시간: 3,142
