주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2014년 4월에 출시된 Apple의 13" MacBook Air 업데이트 모델은 새로운 듀얼 코어 i5 및 i7 프로세서를 탑재했으며, 배터리 사용 시간이 약간 증가했습니다.
Hall effect sensor - screen closed
Hi,
I have just been replacing my screen but the hall effect (sensor that detects the close of the screen to put in sleep mode) is not working anymore. I have found that this sensor is on the I/O board but I do not know where and how I can fix it. Thanks,
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
What part did you replace exactly, the screen assembly ? The hall sensor connects to the I/O board and it’s on the topcase, but it needs the magnet on the lid to be working properly. Unless the sensor was damaged somehow the only reasonable alternative explanation is that your replacement screen is missing the magnet. If you have a magnet around it will be quite easy to verify which of the two fits your case.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
If you replaced the display you might have dislodged the magnet held in the lid frame, or the hall sensor is bad
이미지
Using a rare earth magnet slide it across the uppercase where the sensor is located you should see the display turn on and off as you pass it across the sensor. Use a piece of tape to mark the location and now using a steel paperclip locate the magnet in the lid and marking its location the two marked locations should meet up. If not you either got the wrong lid assembly or the magnet is missing or got placed in the wrong hollow when you replaced the LCD panel.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Pierre-Luc Vérité 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 19
전체 시간: 644
