주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2017년 7월 28일에 출시된 New Nintendo 2DS XL은 기존 2DS 휴대용 게임기를 기술적으로 개선한 리모델링 버전입니다. Nintendo DS 라인업의 아홉 번째이자 마지막 리디자인 모델입니다. 이 게임기는 원본 2DS 모델보다 훨씬 크며, 업데이트된 'New 3DS' 시스템 라인업의 모든 기능을 추가했지만, 상단 화면에서 입체 3D로 게임을 즐기는 기능은 제외되었습니다.
ZL and R Buttons not working.
The R button does not work at all when pressed. It can be pressed but I noticed it doesn’t move as far as the L button. The ZL button, when pressed, causes the system to shut off for some reason. I bought this used off of eBay and it doesn't have a warranty so I’m trying to avoid paying $50+ to get it fixed. My best idea is to check the connections and make sure they’re correct and solid. I can’t imagine how the ZL button got that messed up, I just hope it can be fixed.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 달기
답변 2개
가장 유용한 답변
The cause of this is probably faulty wires.
I would recommend:
Opening it up and fixing it yourself. I’m guessing there’s a faulty connection near the top left hinge, maybe a power cord or ribbon strip that isn’t connecting fully. or,
Take it to an electronics repair store. You'll get the same system back, but fixing a broken system may not fully stop/prevent issues as much as a Nintendo replacement would. or,
Try cleaning the R and ZL buttons, something like Falcon electronics duster cleaner would work for this type of situation.
If none of these work then your system might have a defective motherboard, the only ways to fix this would be to send your system to Nintendo for repair or check it with an ohmmeter.
Hope this helps (:
이 답변이 도움이 되었나요?
점수 5
댓글 달기
Sounds like there's something obstructing your R button, so a cleaning should fix that. ZL, on the other hand, won't be so easy. Someone probably tried to open the friction fit connector near the circle pad and broke it, (DON'T try to do that) so now ZL bumps the cable and causes a short. If it still has some clamping power, I've heard you can wedge something like paper in there to hold the cable down, otherwise the connector probably has to be replaced
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Kyle Hampton 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 25
전체 시간: 4,434
