주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
Battery charging and draining fast
I know the 6s is pretty irrelevant at this point but I’m running into an issue. The phone seems to be charging and dying at a very fast rate. It seems to only deplete while using it though. I have rust replaced the battery and it says life is at 100% but nothing has changed. I think this may have started when I used one of those new fast iPhone chargers that come with the 11. Is this a U2 ic replacement?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
선택된 해법
If the charger you used is an aftermarket and with an aftermarket cable that might easily be the case, but unless one has a Tristar tester it’s not possible to say yes or no for sure. Tristar maybe be the reason as well as any other part that can get shorted for one or another reason, a bump or a simple inner failure. You may try disconnecting parts such as camera, dock, etc to see if you can isolate the issue.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
This is a software issue because with iOS 12/13 apple slowed down older phones and even with a new battery it won’t help the iPhone the only way to fix it is to somehow downgrade the software
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
How do you downgrade software on an iPhone ?
댓글 달기
답변을 추가하세요
David Bertuch 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 16
전체 시간: 2,084
