주요 콘텐츠로 건너뛰기
Announced in August 2017년 8월에 발표된 Galaxy Note8을 회수된 Galaxy Note7의 후속 모델입니다. Note8은 대중이 구매할 수 있도록 2017년 9월에 공개되었습니다.
Black screen, no drop damage
My note 8 screen suddenly stopped working, no drops or known damage of any kind. Just a totally black screen but everything else seems to work, light blinks, it rings when you call, everything. A repair shop that was planning to replace the screen said the screen is ok but the screen power chip is bad. Does anyone know of this is on the logic board or daughterboard? Also, if i replace the logic board, will i lose my data?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Brady Martin “if i replace the logic board, will i lose my data “ yes you will. Your data is stored on a memory IC which is part of your logic board. Not sure which “power chip “ the person you took it to is referring to. U900 is the display PMIC which, in principle could qualify what that person is suspecting. It is on the logic board. I’d suggest you go ahead and follow the troubleshooting as outlined here
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
Thanks so much for the helpful response. I'm just getting into component level repair, so this should help a lot. I'll give it a try
댓글 달기
답변을 추가하세요
Brady Martin 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 6
전체 시간: 292
