주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2019년 12월에 출시된 4세대 Mac Pro의 수리 안내서 및 분해 정보입니다.
Boot RAID installation question
Given the difficulty with user installation of SSDs are there best practices for SSD installation if I want to run a boot RAID? Can I run a boot RAID on this machine? I have been running one on my mid-2010 MacPro, which clocks access times faster than the new machines. Would it be best to install as a PCIe card?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Why? Keep in mind the T2 flash drive array is much faster than a SATA or even the PCIe RAID set even with SATA SSD’s!
The ideal setup is to get as large of base storage (T2 flash) you can hopefully 1 TB. Setup your MacOS and apps on it (typical setup) leave the rest of the drive empty! Now setup your SATA RAID either internally or externally as your data volume keeping your projects on it.
Also remember this system is designed for heavy pro’s in mind. Video & Music creation being the top two. Others which will likely use this system is animation work and very deep graphics designers. While photographers will also likely use it their need is a bit different as its the XDR display which is paramount! As the color correction is important when working on a series of images that need to match up. So the low end model will likely meet their needs and lots of RAM.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Thanks, Dan. You are correct --I was misreading the access speeds. I'm a video guy, so I want something I can upgrade as working resolutions increase.
의 공유
댓글 달기
답변을 추가하세요
William Danton 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 16
전체 시간: 1,199
