주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Ford Fiesta는 1976년부터 Ford Motor Company에서 제조한 소형차(유럽의 B-세그먼트)입니다.
How to correct dtc P0017?
Replaced failed water pump and afterwards got P0017 which is camshaft/crankshaft position correlation bank 1 sensor B that pertains to timing probably one tooth off on timing belt. I was needing help/advice to correct this problem.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
if the code is still up then get a mechanic to read the freeze frame data and they should be able to determine where the issue is, it may be your timing itself but it can also be faulty cam/crank sensors, faulty or damaged wiring, solenoid/actuator, tone ring broken or slipped, it relates to the exhaust cam and crank rather than intake side. if its the teeth or stretched belt/chain it will be over 10 degrees out at idle, check to see if its a chain or belt depending on the engine and what the mileage is for changing them. a good garage should be able to pinpoint the issue without just jumping straight for a new timing set, may save you a few hundred.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
sim é util, por favor quero consertar meu veiculo que é velho e so tenho ele para me locomover
의
댓글 달기
답변을 추가하세요
t41m4dg3 k3mp 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 22
전체 시간: 7,032
