주요 콘텐츠로 건너뛰기
Other than the Tahoe Limited Edition, the vehicle was redesigned for the 2000 model year on the new GMT800 platform, still shared with the full-sized pickups and SUV's.
46 질문 전체 보기
How to stop the low pressure message!
Hi, I’ve been having a problem with my 2003 Yukon XL where I constantly get a low oil pressure warning. I have checked my oil and it’s been full and clean every time. I have had the sensor replaced recently. I was wondering if anyone knows how to just turn the message off or at least make the annoying beeping stop?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 4개
가장 유용한 답변
Hi @kt545,
Since you have replaced the oil pressure sender unit get the engine’s oil pump tested by a mechanic.
If there is insufficient oil pressure in an engine it could damage the engine
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
you would need to disconnect the sensor and program the ecu to ignore both. low oil pressure doesn’t mean dirty and low oil, there’s not enough force pumping it around the car, if the wiring is fine and the sensor there is low pressure, I wouldn’t advise just muting the warning as the engine needs it to lubricate itself and could cause engine failure and an expensive mechanic bill.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Oil pickup o-ring.
Very common
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Get a better diagnosis could be a couple things. Ultimately change everything at once unlike me.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Katie Mcdonough 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 16
30일 전: 54
전체 시간: 2,439
