주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Tahoe 리미티드 에디션을 제외하고, 이 차량은 2000년형 모델을 위해 새로운 GMT800 플랫폼에서 재설계되었으며, 풀사이즈 픽업트럭 및 SUV와 플랫폼을 공유했습니다.
How to stop the low pressure message!
Hi, I’ve been having a problem with my 2003 Yukon XL where I constantly get a low oil pressure warning. I have checked my oil and it’s been full and clean every time. I have had the sensor replaced recently. I was wondering if anyone knows how to just turn the message off or at least make the annoying beeping stop?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 4개
가장 유용한 답변
Hi @kt545,
Since you have replaced the oil pressure sender unit get the engine’s oil pump tested by a mechanic.
If there is insufficient oil pressure in an engine it could damage the engine
이 답변이 도움이 되었나요?
점수 2
댓글 달기
you would need to disconnect the sensor and program the ecu to ignore both. low oil pressure doesn’t mean dirty and low oil, there’s not enough force pumping it around the car, if the wiring is fine and the sensor there is low pressure, I wouldn’t advise just muting the warning as the engine needs it to lubricate itself and could cause engine failure and an expensive mechanic bill.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Oil pickup o-ring.
Very common
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Get a better diagnosis could be a couple things. Ultimately change everything at once unlike me.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Katie Mcdonough 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 7
지난 30일: 33
전체 시간: 3,453
