주요 콘텐츠로 건너뛰기
The third iteration of the 10.1 inch Galaxy Tab tablet.
20 질문 전체 보기
Galaxy Tab 3 won't charge
Hi,
On attempting to charge my Samsung Galaxy Tab 3 10.1 the battery symbol comes up with the lightning bolt inside it but the whole logo just flashes and doesn’t charge the device.
Does anyone know what is happening here?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
Hi, try a different compatible charger (even connected it to a computer) or a different charger cable
이 답변이 도움이 되었나요?
점수 3
댓글 달기
Neil Pattison  if the aforementioned answer do es not resolve the issue then it is possible that you need a new battery Samsung Galaxy Tab 3 10.1 Battery Replacement Also, check the port where the charger connects to. Make sure that it is clean and that there are no bend or broken pins etc. It is repalcable as shown in this guide Samsung Galaxy Tab 3 10.1 Charging Port & Microphone Replacement Worst case scenario would be an issue with the power management IC on the motherboard. So let us know what you find out.
Samsung Galaxy Tab 3 10.1 Charging Port & Microphone 이미지
안내서
난이도:
조정
10 - 45 minutes
Samsung Galaxy Tab 3 10.1 Battery 이미지
안내서
난이도:
조정
10 - 15 minutes
이 답변이 도움이 되었나요?
점수 3
댓글 달기
답변을 추가하세요
Neil Pattison 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 7
전체 시간: 127
