주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2016년 6월에 출시된 Altec Lansing BoomJacket 2는 작고 휴대하기 편리한 블루투스 스피커입니다. 외부 환경에 의한 손상 걱정 없이 어디서든 사용할 수 있도록 설계되었습니다. 모델 번호 IMW579-AB-BB (아쿠아 블루)
My speaker stopped charging.
I've had an apparent short in my circuit forever but always found a way to charge it, by positioning the speaker just right. Now it is not charging at all. Any suggestions?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 3개:
I am having the same problem, but I have isolated it to the power input board. Part number 30-678 Jack MP1.
의 공유
My micro charge connection is damaged. Can anyone recommend a repair center? I reached out to altec lansing but they want proof of purchase. I don’t have my receipt. Any assistance will be great full. TYIA..
의 공유
My micro input is fine. The center conductor looks like it’s pushed in.
의 공유
댓글 달기
답변 1개
My best suggestion would be to replace the charging cable if the problem is cable side. If it's the plug itself unfortunately your going to have to open it up and do some soldering.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I am having the same problem, but I have isolated it to the power input board. Part number 30-678 Jack MP1. The USB connector has come apart and the board needs to be replaced. You will have to find an Altec Lansing repair shop to order a replacement board. Since the speakers are water proof you will have to pry the connecter out of the shell in order to remove power board and it will get ugly.
의 공유
댓글 달기
답변을 추가하세요
dpadget3 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 32
전체 시간: 772
