주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Roccat Kone 게이밍 마우스 수리 정보입니다.
Right click stopped working
Today, whilst gaming my right click stopped working. My mouse is not damaged and it has not been slammed. The right click button simply does not work anymore. How can i solve this issue? Will I need to buy a new mouse? Can I manually open it up myself and fix it?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 3개
가장 유용한 답변
I’ve fixed many mouses myself in the past. You will have to open in and identify the type of switch and verify with continuity that it is the switch that has failed. Assuming that it is the switch it should be fairly straight forward to replace with a soldering iron and some time. If you need help finding the switch in question please post a picture (and if possible accurate dimensions) of it here and i can do my best to help.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
The most gaming mouses use Omron switches. Roccat Kone series also.
But most of them are the cheap ones just hold up to 5 Million Klicks called D2FC-F-7N. You should buy new Omron switches or solder them out of another mouse. Be shure to choose the better switches with (10M) or more as example: D2FC-F-7N(10M). You can use the switches from a broken mouse it doesnt matter, simply solder out the Omron switch of the right mousebutton, because its not so much weared out as the left button.
You can also use the Omron switches from the other buttons inside a mouse, but be aware that those are not made to hold as long as the left/right mousebuttons.
Advanced explanation:
Its quite simple, most of electronic parts have a limited lifetime. The manufacturer put such stuff into the Datasheet of parts. So its clear for the guys who solder this into your mouse and other devices.
But Sellers like Roccat “miss” sometimes to write this info into description …. (your mouse will just stay a live for 3 years, by daily usage of 8h ) i mean thats also not a good argument to sell a product. If you want a mouse that has more lifetime, than only buy those who explicit have as example 50Million Mouseklicks in description. But also there you should be aware that this just means that it could hold up to 50Million Klicks for the two mousebuttons. All other parts are not meaned! The Middle Mousebutton as example in most mouses is often just a cheap part holding for ~200 000 Klicks
Also a accidentally slopped drink on your mouse or very wet weather/climates in your room (above 70% humidity) can cause corrosion in the mouseparts (switches) so they do not work properly. You can clean them but thats very very tricky, so that it is better to solder broken buttons out and put new ones in.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I've had this problem too. However, in my case, it was not due to the switch but to the plastic part that presses on the switch. It had worn down over time and no longer had enough profile to trigger the switch. I solved the problem by sanding it down with a precision grinder and then gluing on a small piece of plastic (I based the dimensions on those of the click that was still working). It's working like new again :)
P.S. for the plastic source, I simply used a zip tie.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Jarred 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 17
지난 30일: 56
전체 시간: 4,145
