주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Razer Blade Stealth는 Razer의 프리미엄 울트라북 라인입니다. 최신 모델은 Razer Blade Stealth (2019)입니다.
How do I replace the SSD?
I just need a guide on how to replace my SSD in my 2019 Razer Blade stealth i7-8565u. If anybody has any experince i would greatly appreciate it. thank you
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
How do you get the case open if the rews are stripped? I tried the method described with a brand new t5. The screws ended up stripped. Is there any way to get it open and replace the screws?
의
댓글 달기
답변 1개
선택된 해법
Two questions to ask yourself before you start.
Do I want to start with a fresh install or clone my hard drive to new?
This is important because the both has different steps. Fresh install is the easiest because you create the boot drive and install windows after installing new drive but with the clone, you need a way to clone the old to new and will require more tools for this type of job.
I can guide you using the fresh install. You will need T5 screw driver and Philips and the new SSD. The SSD that it uses is NVMe M.2 SSD . You can get these on Amazon, eBay, newegg, etc. I recommend the Samsung Evo drives.
I actually found a video that can help you get in the machine, the user also posted a link on how to make the windows boot drive. https://answers.microsoft.com/en-us/wind...
Video: https://www.youtube.com/watch?v=R5dLLkaw...
If you want to do the clone method then let me know and I can guide you with that one also.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
I plan on doing a fresh install from a flash drive. I mostly think I will just need a map guiding me thru the bios before and after the installing the os. I apologize im just really trying not to break or brick my computer. Im not really experienced navigating my way thru there, The links are really helpful tho i apreciate it thank you.
의
@Augustus Pappas No problem. Doing this will not break your computer, just take your time and follow the steps. You won't need to change anything in the bios. If you do the USB boot drive correctly it will auto start when you turn on the computer because it will be looking for a boot image and since the hard drive will be blank, it will choose the usb drive. And a good thing about this is you are doing a clean install on a new drive, so you will still have your old drive that,s working in case it doesn't work. Do let me know if you need anything else and I will be glad to help.
의
댓글 달기
답변을 추가하세요
Augustus Pappas 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 16
지난 30일: 35
전체 시간: 2,109
