주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Citroën이 제조한 자동차 수리 안내서 및 지원.
The car doesn't start
my Citroen c8 doesn't start?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 4개
Could we possibly get some more information?
의 공유
For instance--does the engine turn over?
의 공유
the engine doesn't turn over
의 공유
Since you are really not telling us anything about what your car does or doesn't do. Start witht he basics. Do you have any battery power? Do your dashlights come on? Do your lights come on? Do they go dim when you try to start your car? You need to give more info if you want a definite answer.
의 공유
댓글 달기
답변 3개
선택된 해법
With a broken timing belt you will have:
bent valves
damaged pistons
possibly bent con rods
Or just a useless timing belt. Do not try cranking the motor over (might lead to all issues mentioned above). Take it to a capable garage!
이 답변이 도움이 되었나요?
점수 4
댓글 1개:
Extremely good advice--you can total a engine with a bad timing belt. +
의 공유
댓글 달기
Insert your car's key into the ignition switch and turn clockwise until you hear sounds from the engine bay.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
the timing belt is broken and it damaged the engie
의 공유
댓글 달기
If you have a keyless push button ignition it requires you press on the brake to start. There's a brake pedal switch that performs this function which is a common problem and quick repair.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
solomon 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 23
전체 시간: 2,343
