주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2019년 5월에 출시된 Apple iPod Touch의 7번째 모델입니다. 최대 256GB 저장 용량과 A10 프로세서가 탑재되어 있습니다. 모델 번호 A2178.
How to fix a dropped iPod?
I dropped my Ipod on the ground about an hour ago and it is just the glitchy screen with the lines. How do I fix this techy people? <SOS>
Update: I let it die and then plugged it in and left it alone for a couple hours and it seems to be working fine now. There is still some slight screen flashing but it’s almost unnoticeable.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 7개
Is the screen flickering still happening?
의
slightly, yes
의
Its possible you loosened the connection on your motherboard. There's no cracks or anything on the screen?
의
Awesome glad to hear! It was totally the big UwU energy that fixed it.
의
okay you have to be one of my favorite people in the entire world
의
댓글 2개 더보기
댓글 달기
답변 4개
선택된 해법
it seemed to have fixed itself, thanks for trying though, it means a lot to me. :>
이 답변이 도움이 되었나요?
점수 0
댓글 달기
thank you i would cry if it is broke
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Thank you SO MUCH for this solution. My iPod was flickering after I dropped it, no matter what I tried. But I turned it off (powered off) and let it rest a few hours and the flickering was fixed. I’m so grateful 🙏🏻 . (Note: one hour was not long enough, was still flickering)
의
댓글 달기
My iPod drop and it won’t come on
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
If you scroll up you’ll see that others have said they let it die and then plugged it in and left it alone for a couple of hours and then turn it on again, this fixed the problem. Their suggestions worked for me. Good luck.
의
댓글 달기
it happens with all 7th gens i wanna believe, when you drop it it kinda like makes the phone panic and renderitself useless like some sad lil puppy on the side of the road. just hold the power,volume, and home button down which resets it and when it powers back on it may flicker but thats only because the LCDs were a bit burned for a bit but will ultimately go back to its normal state within a few hours. it depends on how long the phone was in that state. the longer the phone has the lines the longer the flickering and the lines will appear on the screen. I dont know what causes this but if anyone knows please tell me. im very curious
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
UwU_Person 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 8
지난 30일: 35
전체 시간: 6,072
