주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nintendo Switch는 도킹 스테이션을 통해 TV에서 플레이하거나 이동 중에도 플레이할 수 있는 휴대용 게임기입니다. 2017년 3월 3일 출시되었습니다.
Help Removing Stripped BackPlate Screws?
So I had a new Backplate for christmas and was happy to finally replace old plate because of all the scratches, but when I was removing the screws I accidentally stripped 3... Do you guys have any ideas on how to remove those 3 stripped screws?
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 10
댓글 1개
You might be able to use tiny screw extractors like these that iFixit sells:
Precision Screw Extractor Set
Given that the casing is plastic, I wouldn't recommend trying to drill the screw out like you might do with a broken bolt in metal. I also don't think they make a set of easy outs small enough to get those Switch back plate screws out.
의
댓글 달기
답변 2개
가장 유용한 답변
Haven’t done this yet, but my father, whose job was fixing motherboards and other electronical parts, said that the only way is to drill where the screw is, with a drill head as big as the screw itself :/
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
I had to do this on my own Switch recently. It's nerve-wracking but as long as you're careful it gets the job done.
의
댓글 달기
One thing that’s worked really well for me in the past is to put a flat rubber band between the screw and the screwdriver and PUSH — the pressure and added tackiness of the rubberband will allow for the screwdriver to have a better “grip” and get those out.
Also, you’re not alone. Those OEM Switch screws are EASY to strip.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Vince Mada 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 10
지난 7일: 17
지난 30일: 33
전체 시간: 5,761
