주요 콘텐츠로 건너뛰기
2.26 또는 2.4 GHz / 흰색 플라스틱 유니바디 인클로저
645 질문 전체 보기
Spilt water on MacBook, but cannot remove battery
I spilt some water which has gone inside the computer. I stupidly tried swithching it on before allowing to dry. It came on shortly and then went off. I have removed the back cover and want to remove the battery as recommended in other solutions. I cannot do this however as I do not have a tri-wing screwdriver.
1 Is it really essential for me to remove the battery?
2 Is there a way to remove the battery without a tri-wing screwdriver?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
I have managed to remove the battery. Should I leave the bottom cover off while the computer dries?
댓글 달기
답변 1개
가장 유용한 답변
A screwdriver from Radio Shack is a lot cheaper than a logic board replacement.
해당 답변은 도움이 되었습니까?
점수 2
댓글 5개:
Unfortunately I live in Zimbabwe and its 9p.m at the moment.
Ouch! Now is the time to improvise a tri-wing somehow. You do need to remove the battery. Good luck.
What, no Radio Shack in Zimbabwe, what's the world coming to? ;-)
Got the battery out with a flat head screwdriver
Here's the guide on water damage: Electronics Water Damage
댓글 달기
귀하의 답변을 추가하세요
Wilson Luke 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 2,946
