주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Plantronics Backbeat Fit의 후속 모델인 무선 스포츠 헤드폰
Headphones not charging - possible error code?
When connected to power, the device flashes red light 15 times and then doesn’t charge. If i depress the power button once during the flash sequence, the red light goes steady and the device charges normally.
Is the 15 flashes an error code? It’s not mentioned anywhere by Plantronics.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Does it always consistently flash 15 times? If not, sounds to me like you have a borked USB cable.
I've also had an issue in the past where the light went solid red and didn't charge. I figured out that the cable between the ears was damaged and had to order a new headset
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
how did you figure that out?
의
댓글 달기
답변을 추가하세요
Henry Collingridge 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 5
지난 7일: 8
지난 30일: 20
전체 시간: 588
