주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Tiny Tot Driver는 생후 12개월에서 36개월 사이의 유아를 위해 설계된 어린이용 장난감입니다.
Where does this part go?!
이미지
이미지
이미지
Hello friends, so my nephews tiny tot driving wheels horn has been jammed into the wheel (halfway, but stuck) it has the toy on repeat when it is pushed hard and is also happening randomly, with movement of the toy.
So i removed the 11 screws for the casing, removed casing, removed the green lever thingy, im pretty sure it was only held in with one screw.
I was called for help so i had to put the toy down for a while.
When i came back i found a piece that i did not notice.
A little white piece of plastic with a screw hole on one end, a metal clip with 4 prongs on the other & some H shaped leg/brace?
I have looked all over this toy to try find its place but i am STUMPED!
So.
I am now thinking it was held by the same screw that I removed from the green lever.
Perhaps it was under the lever and i didnt see it? And its purpose is to hold the black and red wires in place/ out of the way..?
( edit )
I am pretty sure it belongs here, as in photo 4.
Any help will be much appreciated!
Also going to try unstick the horn button now.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Did you figure this out? I don’t know where it goes either
의
댓글 달기
답변 2개
가장 유용한 답변
This almost looks like the piece that goes behind the red wheel to make it turn. Or to move the clown from button to button
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
The piece does attach with the black back cover to the left of the green clamp holder piece which hold the wheel mechanism in place. If I figure out how to attach a photo I will.
의
댓글 달기
이미지
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Dylan Vetrone 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 36
전체 시간: 739
