주요 콘텐츠로 건너뛰기
2017년 9월 22일 출시. Model A1863, A1905. GSM 또는 CDMA / 64 또는 256 GB / 금색, 은색 및 스페이스 그레이.
873 질문 전체 보기
Bottom Speaker Mesh Damage
I have an iPhone 8. In an effort to remove some dust and debris, I accidentally punctured one of my bottom speaker holes with a thumbtack.
I wanted to know if it worth it to replace the mesh.
I do not want to compromise any water resistance the phone may have by opening up the device.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
As you can see in the product description, ‘Mesh covers are part of the water and dust ingress protection for the phone. ‘
iPhone 8/SE 2020 Speaker and Microphone Mesh Set
So, my answer is yes.
I understand that you do not want to compromise any water resistance the phone may have by opening up the device, but a damaged speaker mesh might also get your phone in a risk of water damage.
iPhone 8/SE 2020 Speaker and Microphone Mesh Set 이미지
상품
$2.99
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
It doesn’t matter it doesn’t affect your phone I put it in for 5 minutes with a mesh puncture and it’s working perfect ??
댓글 달기
가장 유용한 답변
Getting the mesh replaced requires opening up the phone which removes any water resistance when it is opened. Better to leave it as it is.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Depending on which holes you poked.
If it is the right side holes, probably water resistance wasn’t compromised in the first place. You can do a pressure test to determine if the phone is still sealed.
If it is the left side holes, you’ve destroyed water resistance already and it is going to be a complex repair to replace all seals and meshes, and there will be no sure way to test after all this.
So consider water resistance permanently lost if left holes are damaged.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
@tomchai When you say "right side holes" and "left side holes," do you mean speaker holes and microphone holes, respectively?
One hole is damaged. It's one of the speaker holes (if you're looking at the phone, it's on your right side). But it's the hole closest to the charging port (leftmost of the six). Does that make sense?
Do you suggest I do anything in particular?
Thanks
댓글 달기
귀하의 답변을 추가하세요
Emily 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 14
30일 전: 79
전체 시간: 5,696
