주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
CDMA 4G LTE 셀룰러 네트워킹(Verizon)을 지원하는 4세대 Apple iPad의 수리 안내서, 분해 및 문제해결 정보입니다. 16, 32, 64 또는 128GB 저장 용량 모델이 있으며 2012년 11월에 출시되었습니다. 모델 번호 A1460으로 식별할 수 있습니다.
No touch after digitizer replacement
I was brought an iPad 4 CDMA with a broken display. I ordered a replacement and when it arrived I installed it.
Everything went good with the install but there was no touch. I tried disconnecting and connecting it a few times and it did not help. I then hooked up the original broken display and everything worked so I called iFixit and they sent out a replacement.
When that one showed up I installed it and the same thing happened, no touch but the original display works.
There has to be an explanation for this, right?
What am I missing?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
I don’t know what I did different, but I got the display to work.
Thank you for the replies
의
댓글 달기
답변 3개
가장 유용한 답변
I went through at least 4 digitizers to get one that worked properly on an iPad 5. The bad units partially worked — they had dead spots on the touchscreen. Never saw one be completely dead, but I suggest trying again. Make sure you’re getting the correct generation/model digitizer.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I tried pretty much the whole display on both of them and nothing.
The home button that came with both of them does work.
I’ve double checked the model number, so I don’t think that I ordered the wrong part.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Another possibility is that the flex connector is getting dislodged during re-assembly. When you pull up the digitizer check for damage to the flex cable. If it’s ok, then re-seat the cable and test with the unit open to see if you get any response.
I haven’t done gen 4, but on gen 5 the flex cable had to be folded just right for it to fit in without damaging it.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
sunruh 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 20
전체 시간: 402
