주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Ice maker won't fill with water
I just replaced my water supply line between the control valve and water filter on my Kenmore Elite refrigerator. I have good pressure and can dispense water with no problem. However, no water is dispensing to the ice maker. It worked fine before replacing the water line, and the ice maker is turned on. What could the problem be?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
Hi,
What is the model number of the refrigerator?
의
댓글 달기
답변 1개
선택된 해법
Here are some situations that can cause no water to ice maker. Starting with the most common.
A wire came off the water inlet valve.
A failed water inlet valve.
The ice maker is turned off
Tempature at ice maker isn’t below 9*f
Air in the water line
The ice maker hasn’t had enough time to cycle
A problem in the ice maker
The water line to ice maker froze.
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
The light does not light when the ice maker is on position and cannot change size of cubes, but will dispense water.
의
Is there a different motor that runs the ice maker?
의
@barbararod54488
What is the
의
댓글 달기
답변을 추가하세요
Mark T. 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 33
전체 시간: 7,440
