주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Repair guides and support for laptops manufactured by MSI.
Is my ssd upgradeble
hi i have a MSi GL65 95D
but i lack storagespace
i only have a 512 GB SSD
is it possible to replace it or add another
@dasrepair this is how my laptop looks like inside
I've accidentally spilled some soda on the keyboard so some of them are a bit stuck
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
Are you still looking to add additional storage?
no i have added a 1 tb crucial ssd
i need to replace my keyboard
댓글 달기
답변 1개
선택된 해법
yes sir it is. Here is a guide and an opening for you
https://www.youtube.com/watch?v=hocNUfez...
이 답변이 도움이 되었나요?
점수 2
댓글 4개:
Hi @dasrepair ,
I also saw this one but it is not for a GL65 95D it is for a GS650.
The GL65 95d is very new. It looks like it has only been released for about 4 months, so opening it up will void the manufacturer's warranty
opening it up does not void it. There will usually be a sticker above a screw or a part that says if removed MFW will be voided. From the Manfacture site it only has a M.2 nvme slot. I upgraded a decent amount of msi laptops in my shop. The newer models usually have the slot on the opposite side of the motherboard underneath the keyboard. Which is a pain sometimes but not too bad. Regardless upgrading that storage the hard drive its self is expensive.
@akarpti
You can also see from MSI that your model does also allow for a 2.5" drive. https://www.msi.com/Laptop/GL65-9SX-GTX/...
The factory box should also include a sata connection for that 2.5" drive. If you are looking for SSD mass storage then I recommend the Samsung 860 QVO; otherwise Crucial, Samsung, WD, or Kingston's UV line SSDs are highly recommended. I would definitely do a bit a research if you are concered.
-Steve
The sticker is for MSI to check for end user damage in the US. They legally can't void the warranty - it's a bad scare tactic at best.
댓글 달기
답변을 추가하세요
Emil lind 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 7
전체 시간: 430
