주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
이제는 단종된 Minolta 제품군의 필름 및 디지털 카메라 수리 안내서입니다.
MINOLTA SRT-200 Shutter button issue
이미지
PLEASE HELP ME. I have a shutter button issue with my Minolta SRT-200. I recorded a video to explain the issue. Thank you in advance : https://youtu.be/uUvUTI81yEY
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 6개
So the spring is not mounted to the lever. You're lucky!
의
@danj So, is there something I can do? Do I need to mount it? How does one do that?
의
Use a dental pick to drag the hooked end over the lever. Be careful as if you slip the spring can jump off the post to the winds, which is what I had thought you had encountered before.
의
@danj hi dan, i added an updated picture? Did I do this right?!
의
Is it working correctly now?
의
댓글 1개 더보기
댓글 달기
답변 1개
선택된 해법
When you cleaned your system you snagged a small spring which holds the stop lever under tension. Looking at the SRT101 service manual which uses the exact same mechanism the spring 3067 is what you lost referencing this guide page17 Minolta SRT101 Service Manual
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
Hi Dan,
Does that mean I cannot fix it myself? I Don't believe I broke anything as I was very delicate. Is there anything I can do?
의
The spring is as thin as a hair! And it tends to pop off. Its steel, so a magnet will grab it but as it's so small it can get caught in the rug or cleaning cloth.
You'll need to get a new one somehow.
의
I added a picture, i removed the light meter battery holder, can you see it @danj ?
의
댓글 달기
답변을 추가하세요
Emeric Seguin 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 27
전체 시간: 1,240
