주요 콘텐츠로 건너뛰기
The Dell Inspiron 15 (N5050) is a mid-sized laptop manufactured by Dell, Inc. that operates on Windows 7. The laptop features include a WLED HD display screen and a max supported memory of 8 GB.
34 질문 전체 보기
Why did my computer shutoff unexpectedly?
Once again my N5050 shut off unexpectedly and will not start up anymore. It was working fine until I inserted an SD card in the SD slot and suddenly the computer shut off and won't start up anymore.
The computer hasn't used a battery pack in some time due to the one that came with dying a few years ago and has been using regular electricity.
So what can be done? Also, are my files safe?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Files should be safe. Will need to take drive out and connect to an external USB drive interface or connect in a desktop computer.
Do you know that the SD is functioning properly.
Your problem may be due to over heating caused by accumulated dust. If it starts again after a cooling down period then I would suggest unplugging, taking out battery and openning up and blowing out dust with some “canned air”.
If you get the problem fixed do the free upgrade to Winows 10.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Jason Scarce 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 34
