주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Inspiron 15 (N5050)은 Dell, Inc.에서 제조한 Windows 7 기반의 중형 노트북입니다. 이 노트북은 WLED HD 디스플레이 화면과 최대 8 GB의 메모리를 지원합니다.
Why did my computer shutoff unexpectedly?
Once again my N5050 shut off unexpectedly and will not start up anymore. It was working fine until I inserted an SD card in the SD slot and suddenly the computer shut off and won't start up anymore.
The computer hasn't used a battery pack in some time due to the one that came with dying a few years ago and has been using regular electricity.
So what can be done? Also, are my files safe?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Files should be safe. Will need to take drive out and connect to an external USB drive interface or connect in a desktop computer.
Do you know that the SD is functioning properly.
Your problem may be due to over heating caused by accumulated dust. If it starts again after a cooling down period then I would suggest unplugging, taking out battery and openning up and blowing out dust with some “canned air”.
If you get the problem fixed do the free upgrade to Winows 10.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Jason Scarce 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 2
지난 30일: 16
전체 시간: 260
