주요 콘텐츠로 건너뛰기
2018년 9월 21일 출시. Models A1920, A2097, A2098, A2100. GSM 또는 CDMA / eSIM 또는 nano-SIM / 64, 256, 또는 512GB / 은색, 금색 또는 스페이스 그레이. ("iPhone 10 S"로 발음합니다.)
398 질문 전체 보기
What is this thing and how do I fix it?
Hi,
This material between the front glass and stainless steel band on my iPhone XS has been damaged from a fall; a bit of it is kinda scraped off. I think JerryRigEverything called it a buffer or something in his durability video for the XS Max. I don’t know if it’s plastic, rubber or composite.
Attached image shows the material I’m talking about. It’s obviously not my phone; I don’t have a camera with me at the moment, sorry..
1) What is this material and what does it do? Is it rubber? Plastic? Composite?
2) How would I go about replacing it? Do I just get a new display? Does it come with a new display? iPhone XS Screen
Appreciate any help. Thanks :)
iPhone XS Screen 이미지
상품
iPhone XS Screen
$109.99
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 2개
가장 유용한 답변
It’s called the bezel, It’s plastic cast around a metal frame, used to reinforce the screen and serves as structural attachment between the case and the screen. It is adhered to the glass with what looks like industrial strength adhesive and the adhesive loops the whole edge of the glass to make a water resistant seal.
Also it is the sealing interface between the screen assembly and the case. Removing the frame is extremely difficult and there seems no reliable way to reattach a new one to seal properly.
You may need to cut open the metal bezel, remove a few structural screw holes, then try to dissolve the adhesive and cut along the display, refer to below video.
https://www.youtube.com/watch?v=syC-HJLj...
해당 답변은 도움이 되었습니까?
점수 3
댓글 5개:
It's not a bezel, it's a strip of rubber meant to protect from impacts.
@yootzmedia no it’s plastic cast over metal frame, it does provide some bumper space between the screen and case, now ever the core structural element is the metal frame, which holds the glass down
@tomchai @yootzmedia @jaderichards Is it plastic, or is it rubber? Rubber would have a lower melting point, right (correct me if I'm wrong) ? Thanks :)
Plastic. In my opinion, don't do this repair, you'll lose too much for just a cosmetic scuff.
Its a hard plastic in my opinion but is the frame of the whole screen tacked onto the inner metal frame of the screen.
댓글 달기
The piece you are talking about is the bracket that holds the lcd and glass together and holds the screen in place in the phone.
When you replace the screen these are already pre built on the screen. You could choose to replace it but that requires lots of heat and a very steady hand.
Best thing to do is to replace the screen.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Is this "bracket" plastic, rubber, or a composite? I'm curious. This could affect how I heat it. Am trying to be careful.
Thanks a lot :)
It's a rubber meant to absorb energy from impacts to protect the screen.
댓글 달기
귀하의 답변을 추가하세요
Joseph Prekins 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 16
전체 시간: 507
